46RH behind a 3.9L
Old May 2, 2016 | 11:51 AM
blizzblang's Avatar
blizzblang
Default 46RH behind a 3.9L
My 42rh just committed glorious seppuku. It doesn't matter because I wasn't going to need it anyhow, I'm doing the 5.9L swap soon. My question is, can I bolt up a 46rh in it's place till the new motor is ready? I haven't seen any reason why it wont. I'm curious what you guys have to say.
Old May 2, 2016 | 12:32 PM
robertmee's Avatar
robertmee
It'll bolt up but pretty sure it's a different length so you might have to modify drive shaft and tail support.
Old May 2, 2016 | 02:22 PM
onemore94dak's Avatar
onemore94dak
There is a transmission service manual for the 46 and 42 rh on the FAQ page. I know they changed the 42RH in 95 adding more ports and enlarging existing ones. There might be a similar change with the 46RH units.
Old May 2, 2016 | 08:51 PM
blizzblang's Avatar
blizzblang
Should I use my 3.9L torque converter? Or swap in the 5.2L one?
Old May 3, 2016 | 11:44 AM
blizzblang's Avatar
blizzblang
I believe this is only true for 4x4 Dakotas.
Old May 24, 2016 | 09:07 AM
blizzblang's Avatar
blizzblang
So I had to cut the old lines to get it down, and I was wondering, can I run a high pressure rubber hose instead of the metal pipe? I can get the brass fittings for a hose instead of a pipe, but will it hold?
Old May 24, 2016 | 10:09 AM
robertmee's Avatar
robertmee
Sure you can, just make sure it's rated for >300PSI....Something like this:
http://www.oreillyauto.com/site/c/de...0924&ppt=C0222
