Crankshaft position sensor bolts.
Old May 25, 2016 | 11:23 AM
blizzblang's Avatar
blizzblang
Default Crankshaft position sensor bolts.
Those two bolts at the top seem impossible to take out. I'm this close to just pulling out the motor till the 5.9L is ready...
I almost stripped out the head on the bottom picture.
Old May 25, 2016 | 03:05 PM
onemore94dak's Avatar
onemore94dak
I know that's a real tight spot I have the scar to prove it. IDK what to do? Can you sacrifice and weld the hex bit to that bolt and take it out that way? EDIT I seem to remember that my Crank Sensor bolts had a hex head that a socket fit on so you might check with the dealer to find out the correct fastener to use there. It could be that yours is correct since they used both metric and standard sizes on these motors they might have used the type of hex driver bolt you have OE on yours.
Old May 26, 2016 | 01:07 AM
Friar Tuck's Avatar
Friar Tuck
Visegrips?
Old May 26, 2016 | 09:41 AM
robertmee's Avatar
robertmee
I had to do a weld on the locking pin bolt on my differential. You might also try a chisel/hammer and tap the grooves of the head...you'll want to get as far outside of center and still get bite into a groove. Don't tap in the center or you could shear the head off.
Old May 27, 2016 | 02:23 PM
onemore94dak
Another thing is if you can get a torch in there and heat the head of that bolt to cherry red that should break it loose which is what would also happen if you welded something onto it.
Old May 27, 2016 | 03:25 PM
blizzblang's Avatar
blizzblang
I ordered an allen wrench set, cheap one I may get some use out of larer. Gonna see if I can get it loose without loosening it. Then I'll jb-weld in in place then crank. When I put the new one in I'll use actual bolts.
