Any AX-15 trans changes from 92-95 ?
Old Jun 23, 2016 | 10:00 AM
bfowler92's Avatar
bfowler92
Default Any AX-15 trans changes from 92-95 ?
Hi Guys Ive got another line on an engine from a 94 Dakota . Doing some research on here and elsewhere had me thinking that the trans from those years were the same. Any engine from 92-95 would drop right in with no issues but now I'm not so sure. I read on allpar that in 93 they used a "quieter 5 speed manual behind the 4 cylinder" and I had never heard that before. On this site it just says the ax-15 was used 92 and on. Looking at clutch kits online I see for 92 2.5L they only offer a 19 tooth spline clutch kit versus the 94 2.5 only shows a 10 tooth spline clutch kit. So I'm questioning what trans was behind the 94, was it just an updated ax-15 with the same bellhousing pattern and lower spline count? If so does it still share the same pilot bushing/ crank journal depth and diameter ? The pilot bearings seem to be the same when buying online so I would imagine so but I've already made a 400 mistake once and don't want to do it again. Let me know what you all think. Thanks
Old Jun 23, 2016 | 01:48 PM
robertmee's Avatar
robertmee
The AX15 changed in 94 but not sure enough that you can't swap the engines. Here is some info on the ax15 changes http://www.novak-adapt.com/knowledge/transmissions/manual/ax15
Old Jun 23, 2016 | 05:38 PM
bfowler92's Avatar
bfowler92
Originally Posted by robertmee
The AX15 changed in 94 but not sure enough that you can't swap the engines. Here is some info on the ax15 changes http://www.novak-adapt.com/knowledge...ns/manual/ax15
Thanks for the info, If the number of spines changed that's fine since I am going to use my clutch assembly. I need to know if the pilot bearing/crank journal for the bearing is the same. That's my issue, I'm sure the bellhousing is the same.
