'92 4x4 door emblems
Old Jul 9, 2016 | 12:51 PM
lsigrandson's Avatar
lsigrandson
Default '92 4x4 door emblems
Does anyone know where I can get some replacement door 4x4 emblems for my '92 Dakota? I lost the one on the driver's door, and as a precaution, I removed and applied silicone to the one on the passenger side. I've done some searching on the 'net and have come up empty. My last resort would be to check out some junk yards.
- Mike
Old Jul 9, 2016 | 01:32 PM
RalphP's Avatar
RalphP
Boneyards may be it, alas.
Well, there, and keep checking Ebay and Amazon.
Also, that's not listed on the door of the 1992 in the parts list (see the FAQ for a downloadable copy); however, there's four listed for the tailgate.
You can see the part numbers as item #3 at http://www.moparpartsgiant.com/parts...es-decals.html .
RwP
Old Jul 9, 2016 | 01:54 PM
lsigrandson
Thanks for the info RalphP. Boneyards it may well be.....
Old Jul 16, 2016 | 06:11 PM
angrysmileyface's Avatar
angrysmileyface
I got mine on ebay. What I'm looking for is the big rubber molding
Old Jul 17, 2016 | 08:49 AM
robertmee's Avatar
robertmee
What molding are you needing? I'm restoring a 90 vert that has the trim molding around the truck. I don't think I will be reusing. I have all the pieces except one across passenger door...well I have it too but someone peeled it off and it's curled pretty bad. I haven't remove the molding yet...as I understand, the pieces in the front and door are glued on and the pieces behind the rear quarter are held on by fasteners. So I could try to remove without damaging.
Old Jul 20, 2016 | 12:22 PM
tbugden's Avatar
tbugden
I have some of those ugly (I think) rubber moldings too I don't need or want but probably only for the box and part of the cab. They're kind of faded I think. Located in CT, I sure wouldn't want any money for what I have if someone wants them for some reason. All of my molding was held with adhesive and all of it came off very easily with a heat gun. Heated enough to pull up the starting edge of the molding, shove a putty knife under it to pry it a little, then pull it off by hand, easy.
Old Jul 20, 2016 | 06:20 PM
lsigrandson
I just scored a pair on eBay, and there are still a few more being offered if anyone is looking. Believe it or not, my moulding is still in good shape although it is fading a bit.
- Mike
