Wrong driveshaft?
Old Jul 27, 2016 | 01:34 PM
blizzblang's Avatar
blizzblang
Default Wrong driveshaft?
Putting an AX-15 behind my v6, and I bought this driveshaft through car-part.com . I have the ext cab, so my wheelbase is 131", and I'm looking for a manual driveshaft that uses the AX-15 spline count. Anyway, I got one I found home, and it's the same length as my automatic driveshaft. It supposedly came out of a manual the day before. Aren't the ax15 and nv2500 the same length? I did some measurments and found the 'new' driveshaft to be about 7 inches too short. Any help?
Darker one was the automatic. The lighter one was out of a manual.
Old Jul 27, 2016 | 02:53 PM
Toby Warford's Avatar
Toby Warford
To me, the look identical except for the end piece. Why not just swap it out to the one you need? The difference may be between a 2wd and 4wd rear end. I'm not sure though, but I'd say you still have a usuavle drive shaft between the two.
Old Jul 27, 2016 | 04:38 PM
onemore94dak's Avatar
onemore94dak
Can you mock it up to be sure it is short? I have heard that people weld in sections to extend them or weld them after shortening them. I found this in a search. http://driveshaftsunlimited.com/ They might be willing to answer questions for you. I forget what trans & what motor you were changing to. Anyway they say the do OEM so??? Good Luck.
Old Jul 28, 2016 | 08:48 AM
Michael McNeill's Avatar
Michael McNeill
I wouldn't try lengthening/shortening the shaft yourself unless you can do it just by mixing parts between the two. If it's going to have to be cut/welded, take it to a truck shop (like box trucks/tractor trailer), most of them are set up to make/modify driveshafts, and are usually pretty cheap. I think the last one I had shortened cost me like $60 or less.
Old Jul 28, 2016 | 09:14 PM
blizzblang's Avatar
blizzblang
Are the AX15 and the nv3500 the same length 2wd?
Old Jul 28, 2016 | 10:43 PM
robertmee's Avatar
robertmee
Lots of good info in here
https://dodgeforum.com/forum/1st-gen-dakota/382160-87-91-nv3500-ax-15-a-2.html
