Flames out exhaust!?
Old Sep 9, 2016 | 09:00 PM
Grease_Junkie's Avatar
Grease_Junkie
Default Flames out exhaust!?
Hows everyone doing? So just put autolite 3923 plugs in and fired it up, has old gas probably 6months old cause i havent touched it much, its shooting flames out the tail pipe amd popping at idle. Have changed iac, crank cam sensor intake and plenum. Now it has a coupling in ypipe right under tranny and i believe its sucking in air where its so close to manifolds causing constant popping. You guys know more about magnums them me. Its 92 5.2 134xxx miles thank you
Old Sep 9, 2016 | 09:38 PM
RalphP's Avatar
RalphP
Fix that exhaust leak.
IF the O2s are working, it'll be sucking extra air in, so it'll be running rich, so ...
Also, if you haven't done the O2s, try those along with sealing that exhaust up.
RwP
Old Sep 9, 2016 | 09:44 PM
Grease_Junkie
10 4 probably gonna have to slap a turn down tip on so it doesnt blow my gas tank up. Preciate it i figured it had to be why and not my plenum
Old Sep 9, 2016 | 10:46 PM
RalphP's Avatar
RalphP
That plenum, if it's got oil in it, isn't going to help it any due to ITS vacuum leak; but yah, things that directly affect it, get those first *grins*
RwP
Old Sep 10, 2016 | 12:48 AM
Toby Warford's Avatar
Toby Warford
To me, sounds like 2 or 4 plugs are crossed. When I swapped in my headers I had 6 crossed by mistake. Swapped two, and it ran, but sounded like the headers were leaking. Swapped two more and it was better but still popped. Swapped the last two I had crossed and all was fine.
So, yes, your v8 will run with 4 plug wires crossed. I'd check that. Just to make sure.
