'93 Dakota motor 318
Put 318 into '89 Jeep Wrangler. Had it running for 3 weeks after changing out ECU. Due to loose internal parts. I have spark to body on plugs, injector spark, have 40psi on fuel gauge. New mass sensor, New fuel regulator. Put in new crank sensor when installed motor. Put in new plugs after install. Getting fuel to plugs. Throttle position getting Voltage. Won't start with starting fluid. I'm thinking ECU went bad again. Any input would be greatly appreciated. Thank you.
