hooking up nitrous to my 1995 dakota.
i have a zex nitrous kit that i am putting on my 5.2l. it hooks up to the tps. which wire would read wide open to tap the zex wire to?
The red one.
i looked at it i have 3 wires coming our black purple and orange. i looked at my book and it has ground 5v and throttle position. just wanting to make sure before i pour to it. lol also would you know where the fuel pressure regulator.
Moved to 1st Gen Dakota.
Throttle position, and the regulator is at the tank.
RwP |
i looked at my book and stuff. it shows the fuel pressure reg at the intake. my solenoid needs to hook up to the fuel pressure reg vac line.
When I look up (rock auto) a 95 5.2 dakota, they show no pressure regulator, however when I look up the fuel pump assy for the same truck they show its included or part of the fuel pump assy in the tank.
BTW is that a wet or dry system you are installing? FWIW I prefer the wet system myself. |
Originally Posted by demonkota
(Post 3329684)
MY copy of the 1995 FSM, on page 14-8, at the start of the last section (section named "FUEL SYSTEM PRESSURE TEST—3.9L/5.2L ENGINE") has: The vacuum assisted fuel pressure regulator located at the rear of the fuel rail is no longer used on the 3.9L or 5.2L engine. Fuel systems on the 3.9L/5.2L engines are equipped with a fuel tank module mounted, combination fuel filter/fuel pressure regulator (Fig. 8). The fuel pressure regulator is a mechanical device that is not controlled by the powertrain control module (PCM) or engine vacuum. |
dry system.
just got it running today and got not even a mile from my garage and the damn fuel pump went out.... yeah i dont know y the book tells me that the fpr is at the intake cause when i went to price my fuel pump assm. it was on it.... |
