What are these called and can you buy them?
Old Feb 15, 2017 | 09:11 AM
robertmee's Avatar
robertmee
Default What are these called and can you buy them?
In removing my rear harness, almost all the connectors have these pieces on them for securing to the frame. But mine are all mangled, broken or otherwise unsightly. I can use rivet style zip ties to hold the connectors to the frame, but if I could find these little rivet clips, that would be much better. I've tried countless google search combinations and have yet to even find a picture of one by itself. One problem is I don't know what they are called. It's the small flat piece with the xmas tree rivet (circled in red). These actually are detachable from the connector so that you can remove the connector from the frame but leave these rivets secured in the frame. But since I removed all mine to paint the frame, most are destroyed.
Old Feb 15, 2017 | 09:38 AM
robertmee's Avatar
robertmee
Picture of one of mine
Old Feb 15, 2017 | 02:50 PM
onemore94dak's Avatar
onemore94dak
Try "Wire harness retainer clip"
Old Feb 15, 2017 | 05:32 PM
robertmee's Avatar
robertmee
Yeah, I've tried that, plus "fir tree clip", "connector clip", "Connector rivet", with and without Dodge or Mopar in the search. The closest I have found are these:
http://www.delphi.com/manufacturers/...s-routing-aids
But not quite a match.
Old Feb 15, 2017 | 05:40 PM
robertmee's Avatar
robertmee
Getting closer, but still no cigar
http://www.digikey.com/products/en/c...=0&pageSize=25
Old Feb 15, 2017 | 08:55 PM
onemore94dak
There are a lot of similar wire clips that tape to the wire and might work with that groove if you search that term. Try sending that picture to these guys www.clipsandfasteners.com
