Truck "shudders" a little at decelerating
Old Feb 15, 2017 | 09:50 AM
Turtle1995's Avatar
Turtle1995
Default Truck "shudders" a little at decelerating
Hi everyone! Recently my 95 Dakota 2wd shudders a little when coasting from 40mph to 25. It started after I got new brake lines, hoses and rear wheel cylinders, but I have yet to put in new pads and shoes, hardware and drums, which are shot. BTW, I guess I haven't had rear brakes for about a year. My ujoints have been squeaking a lot too and have to be replaced.
Old Feb 15, 2017 | 09:53 AM
robertmee's Avatar
robertmee
when coasting (letting off the gas pedal) or when braking (applying brakes)? Do you feel the shudder through the steering wheel or only in the rear?
Old Feb 15, 2017 | 02:03 PM
Turtle1995's Avatar
Turtle1995
When coasting, I can feel it in the seat and sense it's coming from the rear of the truck.
Old Feb 15, 2017 | 05:26 PM
robertmee's Avatar
robertmee
I'm going to guess pinion wear in the diff, but wait for someone else that knows better than me. When the engine/trans is driving the drive shaft, the teeth are meshed on one side...but when you coast, the wheels are now turning faster than the drive shaft and the teeth hit the other side...so wear gap can cause shudder.
Old Feb 15, 2017 | 08:59 PM
primem's Avatar
primem
if you coast down in neutral is the vibration gone?
Old Feb 16, 2017 | 04:18 PM
onemore94dak's Avatar
onemore94dak
It could also be one of the tires.
