toggle on fuel pump??
ok im bout tired of trying to run down what in the hell is going on with my fuel pump. ill be installing an after market fuel pump later on to push more fuel as i am going to be doing some more upgrades. anyone know what wires i need to cut into to run the pump to a toggle switch???
You could just jump the ASD, which is what controls the voltage. n Just be aware of what ELSE is broken if the ASD isn't working. Besides, how do you know that jumping there will fix the problem without proper troubleshooting?
I'm with onemore94dak; without the factory service manual's wiring diagram, you're pissing in the wind.
RwP
RwP
