Deceleration on acceleration
Old Mar 6, 2017 | 04:50 PM
Cindij's Avatar
Cindij
Default Deceleration on acceleration
I have a 1990 dakota 3.9 litre and while trying to accelerate it decelerates and acts like its running out of gas, I've tried throddling the pedal to get it to go and that doesn't help at all I'm scratching my head on the problem I know there could be a number of things it could be
Old Mar 6, 2017 | 05:13 PM
robertmee's Avatar
robertmee
start with the easy stuff....when was the last time you changed the inline fuel filter? Have you tried cleaning the TPS? Have you checked your fuel pressure? Sounds to me like a fuel delivery issue....starving.
Old Mar 6, 2017 | 06:38 PM
RalphP's Avatar
RalphP
I'd DEFINATELY check the fuel filter.
I'd also check that the cat isn't clogged.
Of course, the usual suspects - How long since the last full tuneup (plugs, wires, cap, rotor)? How's the ignition timing on it (the 1990 is a LA block, you can still set timing on it)? How old is the air filter? What kind of shape is the transmission fluid in?
All things that you should check or verify first.
RwP
Old Apr 3, 2017 | 05:52 PM
Cindij's Avatar
Cindij
Checked fuel pressure and changed fuel filter nothing seems like an issue still doesn't run like it should and now battery is fully charged but acts like a dead battery. I jump start it with another vehicle and it will start and alternator is charging but if you turn the engine off it won't start without a jump. Did a visual inspection of possibly a bad wire connection or damage but nothing obvious ughh
Old Apr 3, 2017 | 06:42 PM
onemore94dak's Avatar
onemore94dak
Read the FAQ page and do the code check it describes using the key. What state is it in when you have this deceleration reaction? Is it driving along normally then gives out when you try to speed up or??? Get the codes, there is a link to the list of what they mean in the same section. They might give some indication what's causing the electrical issue. Could be a fuse, relay or??
Old Apr 3, 2017 | 08:15 PM
RalphP's Avatar
RalphP
On the electrical - check all the battery cable connections. ALL the connections; battery end and other end.
Check the cables themselves; sometimes they'll suffer "green rot" inside.
On the "decelleration on acceleration" - have your exhaust system checked to verify it's not plugged also. Easiest home way is to pull the upstream (or sometimes only!) O2 sensor, start it up, and see how it feels (leave the O2 sensor attached to the wiring; wire tie it up out of the way for this test, and THIS IS JUST A TEST. DO NOT DRIVE IT LIKE THIS!!!)
RwP
Old Apr 3, 2017 | 08:21 PM
smokin1994's Avatar
smokin1994
ignition switch?
Old Apr 4, 2017 | 12:50 PM
Cindij's Avatar
Cindij
The deceleration can occur anytime it started out when I would try to pick up speed it would act like it was trying to run outa gas but now I can be basicly idle speed as I live off grid and a lot of slow going dirt roads it acts like its trying to run outa gas so there really isn't a specific action that I can pin point which is frustrating. Ive been wrenching on cars since my teens so I'm not totally ignorant on these subjects but there doesn't seem to be an obvious fix (Sigh)
Old Apr 4, 2017 | 01:04 PM
RalphP's Avatar
RalphP
Well, first you need to find out - is it having trouble getting fuel in? Is it having trouble getting air in? Is it having trouble getting exhaust out?
RwP
Old Jan 10, 2019 | 12:17 PM
Cindij's Avatar
Cindij
Well the outcome and final fix after peaking and tweaking with no fix I put in a new fuel pump and now it works fine. Thanx for all of your input I greatly appreciate it
