Performance camshaft with stock ecu
Old Mar 15, 2017 | 10:28 PM
Bearclaw2009's Avatar
Bearclaw2009
Default Performance camshaft with stock ecu
I'm looking to do a V8 swap in my 95 Dakota. I'm pricing it all out to get a used motor and freshing it up with new gaskets and rebuilt heads and upgraded cam. I'm not going to go with an aggressive cam but one that is computer compliant according to the specs. My question is what do I do about the ECU so it will run correct. I've talked to jet and they can't do anything for it and superchips don't show chips for the obd1. Any advice on what to do for this would be very helpful.
Old Mar 16, 2017 | 01:46 AM
RalphP's Avatar
RalphP
Rewire to use a 1996 ECU, and get Flyin' Ryan to do it (since the 96 was OBDII).
Or trust that the ECU can self-correct.
Or find a good, used Mopar Performance ECU for a 1995 Dakota V8.
RwP
Old Mar 16, 2017 | 02:02 AM
Bearclaw2009
What would it take to convert it to a 96 ECU
Old Mar 16, 2017 | 02:18 AM
RalphP's Avatar
RalphP
I haven't double checked, but at least the body harness; the ECU; and the inside wiring.
*looks at list*
Basically, ALL the wiring.
RwP
Old Mar 16, 2017 | 03:42 AM
Bearclaw2009
Has anyone installed a cam on a stock ECU and can shed some light on what to do
Old Mar 20, 2017 | 11:21 PM
Bearclaw2009
So I decided to just swap out the v6 for a 5.2 what ecu's can u use I have a 5speed so can I use a ECU for a auto or do I have to stick with a manual computer
Old Mar 21, 2017 | 06:08 AM
RalphP's Avatar
RalphP
You CAN, but it'll toss codes due to the overdrive and lockup solenoids not working. Since the 5 speed doesn't have them.
A 5.2 ECU from 1994 or 1995 should fit and work; all that's really needed wiring wise is the two extra wires for injectors 7 and 8.
You'll also need a V8 flywheel and fan shroud. And I'd recommend if the motor isn't a 1994/1995, you upgrade to the 1994/1995 fuel injectors.
RwP
Old Mar 21, 2017 | 12:19 PM
Bearclaw2009
The motor is from a 99 1500 but it doesn't have a fuel rail or injectors or distributor
Old Mar 23, 2017 | 08:46 AM
Carl_S's Avatar
Carl_S
Someone removed them ? Every salvage yard I go to, the first thing removed is the throttle body and intake. Fortunately I'm usually looking for other parts. keep us posted on how it works out. I'd love to have a v-8 in my 90 but it'd be too much work.
Old Mar 24, 2017 | 07:19 AM
volaredon's Avatar
volaredon
motor itself is same from 92-03, sensors and injectors and whether it would have had EGR (or not) changes by year and California or Hi altitude (or not)
