Starts out in second gear when in Drive
Old Mar 21, 2017 | 09:36 PM
Seth Jillian Dault's Avatar
Seth Jillian Dault
Default Starts out in second gear when in Drive
Im bout to be buying a 94 dodge dakota with a V6 engine in good condition has between 160,000 - 180,000 miles on it runs and drives the only problem is it starts you out in second gear when in drive but shifts into 3rd, 4th, and 5th gear perfectly fine i was told it had a bad tranny sensor is what the guy told me after he took it to a shop but when i ask around to fellas i know they say i would need to replace the whole tranny i need a correct answer somebody help me out please.
Old Mar 22, 2017 | 09:33 AM
RalphP's Avatar
RalphP
Uuuhhh ...
There's something wrong. For 1994, the automatic is a 3 speed with overdrive; or gears 1,2,3, and 4.
You list 4 gears.
Sounds like it's working to me.
RwP
Old Mar 22, 2017 | 12:27 PM
robertmee's Avatar
robertmee
What Ralph said...94s are 4 speed only. There is no 5th gear. Regardless you wouldn't have to replace the tranny...rebuild the valve body if there is a shift problem only and no grinding of gears...you can drop the valve body and a shift kit to rebuild it is about $80. Another $20 if a servo has gone bad.
