92 dakota mysterious wheel cylinder bolt size?
Working on this cobbled up truck. Trying to remove a blown left wheel cylinder, and no socket fits it. And Google is worthless.
can anyone give me insight?
3/8
5/16
9mm
10mm
none if these fit. 3/8 and 10 just spin.
5/16 and 9 don't even go on.
in at my wits end with this truck.
3/8
5/16
9mm
10mm
My two cents is that you should change both of them at the same time. I had my rear wheels lock up on me 500 miles from home. Luckily it let go and worked normally the trip home. When I got home it turned out a previous owner had only changed one wheel cylinder and the older one crapped out.
10mm is slightly larger than 3/8. if you started with 10mm you might have rounded the bolt head! Try one thing; do you know anyone with any Snap on tools? try, just try a Snap on 3/8 6 point socket. I have gotten so many fasteners off with Snap on that I had given up on with other tools.... you may need to slightly hammer (tap) the socket on.
