Best place to buy front brake pads for 88 Dakota 3.9 V6 2WD?
Where is the best place to buy front brake pads for my 88 Dakota 3.9 V6 2WD single cab pickup? The front brake pads from NAPA are riveted & I don't like brake pads that are riveted, due to the fact that I am afraid that when the pads wear down, the rivets will be able to wear into the rotors. That's just my fear, may not be nothing to it!
Also, I've had "bonded" pads lose the pad material. I prefer riveted.
However.
You can always check out The Usual Suspect (Rockauto.COM) and pick pads from there.
RwP
I buy brake parts locally. That way, if I have issues, I can take care of it with them instead of over the internet. You also get lifetime warranties on parts purchased through chains (advance auto, autozone, o'reillys, etc) I buy the middle of the road stuff. Not the cheapest, not the most expensive. Never had a problem.
Last job I did I put in Timken bearings inner and outer and Raybestos rotor/hubs. And Raybestos riveted brake pads ...
RockAuto does have pics, so you can verify that, for instance, the Midas pads are bonded, but the Raybestos premium pads are riveted, etc.
Just keep good pads and rotors on it, and keep those bearings greased.
RwP
