code 32 and 45
Old May 15, 2017 | 09:27 AM
charlie2dogs's Avatar
charlie2dogs
Default code 32 and 45
I have a 1992 dodge dakota le, 3.9 magnum, auto trans with 98,000 mi. i am getting a code 32 and 45, i have checked the egr valve and the port is clean, and it isnt stuck could any of you more experienced young guys advise and old guy with this and help me with some ideas as to how to go about getting it straightened out, thanks for any help,
Old May 15, 2017 | 08:27 PM
onemore94dak's Avatar
onemore94dak
With the 32 code I found that changing oil, the air cleaners and keeping the thing tuned helps. I had one going off every couple weeks. then it stopped. IDK that I did anything to fix it but I cleaned it twice. If you had it off might as well spray it and brush it. Maybe blow out the vac lines or test them for leaks. The 45 is a solenoid on the trans, IDK exactly where.
