WTB new control arms
Old May 17, 2017 | 11:03 PM
dakotakid17's Avatar
dakotakid17
Default WTB new control arms
dose anyone know where i can find new lower and upper control arms for a 4wd dak all i can seem to find is bushing also the alignment bolts for the upper control arm?
Old May 18, 2017 | 05:32 AM
RalphP's Avatar
RalphP
To buy new ones, first you must build a time machine ...
They've been NLA for a few years now.
It may also help to specify which year, because there may have been design changes between 1987 and 1996.
As to the UCA mounting bolts, those can be done with standard Grade 8 or higher bolts; the T-head is nice, though. 9/16 Fine thread, if you're looking for them. Also, if junkyard cruising, they're in the front of most RWD Mopar products from the late 50's on.
RwP
Old May 18, 2017 | 10:10 PM
dakotakid17
its a 94 shart cab short bed v8 5 speed
Old May 20, 2017 | 01:26 AM
shadowthedakota's Avatar
shadowthedakota
The change waant until possibly 97 when they went with a wider wheel base for the wider body. Best bet is to get some from a junkyard or ebay and sandbalst them or wire wheel them and paint them.. second gens might work but they might be wider as I stated earlier.
Old May 20, 2017 | 01:31 AM
shadowthedakota
If you're close to milwaukee, wi Id sell you the set i have off my 93 frame. They're good just need to clean them up and paint them
