Help me
Old Jun 7, 2017 | 05:53 PM
Charles Dickerson's Avatar
Charles Dickerson
Default Help me
So my egr tube snaped can I eliminate it or will it cause problems. It's in a 3.9 v6 dakota
Old Jun 7, 2017 | 09:17 PM
ragged89's Avatar
ragged89
Where did it snap? In a pinch you could sleeve it with a slightly smaller metal tube. Just coat the sleeve with some muffler-weld epoxy first. After you sleeve it test fit it, then install it in place before it sets up, otherwise you'll play hell getting it to line up.
I wouldn't eliminate it. The small amount of exhaust gases recirculated makes combustion more efficient and increases your mpg (slightly). There are block-off plates available, but then a new tube is only $40 or so.
https://www.moparpartsoverstock.com/...FUGTfgod4UIGKg
Old Jun 8, 2017 | 09:40 AM
onemore94dak's Avatar
onemore94dak
I advocate fixing it. In spite of issues due to lazy engineering on some newer motors modern motors are more efficient and better than anything that came before. I advocate going with the stock setup unless there is a known improvement. I had a hard time finding one since you did not put the year but I found this link http://www.factorychryslerparts.com/.../53009189.html Now at least you have a part number to help your search. Edit DOH! palm forehead did not see the link ragged gave
