Convertible Windshield Trim
Old Jun 13, 2017 | 08:09 PM
Ourgoo's Avatar
Ourgoo
Default Convertible Windshield Trim
Can anyone tell me how to remove the metal windshield header trim from a convertible. It's where the top meets the body. It's held captive by a clip at each end. Need to take them off without damaging them. End clips appear to have to be bent upward to release. Looking for some knowledge.
Thanks.
Old Jun 14, 2017 | 08:11 PM
Ourgoo's Avatar
Ourgoo
Figured it out. End caps slide off of the header with a little persuasion. Then the main trim piece can be gently persuaded to slide along the retainer clips until it's off of the header.
Old Jun 15, 2017 | 03:42 PM
ragged89's Avatar
ragged89
You got it. Be careful with that rubber seal, it rips easily where its thin, and you'll never find another without extreme good luck.
Old Jun 16, 2017 | 06:08 PM
Ourgoo's Avatar
Ourgoo
Thanks Ragged. You're right! I just got it removed. Managed to keep it all in good shape. Trim is a bit rusty. A little sanding and some satin lblack and we will be as good as new. You're right about the seals. Don't think there's many left on the planet!
Old Jun 17, 2017 | 10:33 AM
ragged89's Avatar
ragged89
Convertible Dakota parts are like dinosaur eggs, hard to find and very fragile.
My trim strip is rusty too. When I have an opportunity I'm going to try an electrolysis bath to remove the rust. That way I won't have to scratch the heck out of it trying to get all the rust off. It's not rusted through or anything, but a lot of surface rust.
