Wiper Linkage
Old Sep 2, 2017 | 11:51 AM
Dakota1996SLT's Avatar
Dakota1996SLT
Default Wiper Linkage
Can anyone send me a diagram of the windshield wiper linkage for the 1996 Dodge Dakota? Would like to look it over before going into it, would help in making sure I put it back together correctly.
Old Sep 2, 2017 | 12:58 PM
RalphP's Avatar
RalphP
There's an exploded parts diagram at http://www.factorychryslerparts.com/...category=20301 ; also, see attached page 1 of section 8K from the 1995 factory service manual (that's the FSM diagram; section 8K is for the windshield wipers)
Edit: If your problem is that the bushings have failed, you can buy them; check DormanProducts.COM for the part numbers of the packages (usually sold as HELP! or AutoGrade or some such brand at the parts store.)
RwP
Old Sep 3, 2017 | 02:49 PM
angrysmileyface's Avatar
angrysmileyface
If you do bushings fill them with a little bearing grease. It will prolong the change out for when they wear again.
Old Sep 3, 2017 | 03:06 PM
RalphP's Avatar
RalphP
This.
I used a moly lithium grease (won't deny it, it's what I use for front end parts and U-joints too!) and the only problem I've had is that it popped out one night. Replaced the blades and so far no repeats.
(I also run a 20" driver's and a 16" or so passenger wiper, so I get even more cleaned off where I'm looking at ... that extra load probably doesn't help much!)
RwP
