overdrive solonoid?
Old Sep 14, 2017 | 10:16 PM
hydeaway's Avatar
hydeaway
Default overdrive solonoid?
i have a 92 dakota le. the overdrive isnt working and i do not have lockout (4th gear). i do not have the switch but have tried running a jump wire to the different pins in the port. i have a feeling that this is cause by a bad solonoid but i am not sure how to test it.
Old Sep 15, 2017 | 07:45 AM
robertmee's Avatar
robertmee
The middle pin should have 12vdc. The two outer pins are your lockup and overdrive solenoid grounds. 4th gear is overdrive not lockup. Lockup occurs after overdrive.
if both solenoids are not working could be the 12v is missing....check the center pin on the connector for voltage with a meter or test light. To test solenoids run a 12v jumper from battery to center pin on trans. Then ground each outer pin to a good ground point. Listen for an audible click from the solenoids....theyre in the valve body inside the pan.
