Replacement Thermostat Housing
Old Nov 24, 2017 | 09:57 PM
RalphP's Avatar
RalphP
Default Replacement Thermostat Housing
The Four Seasons thermostat housing (a casting, not a stamping welded together) is back available at RockAuto:
http://www.rockauto.com/en/catalog/d...r+outlet,10337
RwP
Old Nov 26, 2017 | 09:35 AM
Brian in Tucson's Avatar
Brian in Tucson
Is there anything to be gained by using a cast housing? I've replaced mine with the Dorman housing and it seals well and works good.
Old Nov 26, 2017 | 10:06 AM
RalphP's Avatar
RalphP
For me, it was better sealing; the stamping can warp easily with age.
I'm going to mis-quote a local ad:
"If you've got one that works and seals properly, use it! If however you're looking for a new one, here's the casting." *grins*
Replacement will take two new bolts about 1/4" longer to properly seal, too.
RwP
Old Dec 4, 2023 | 03:55 PM
MtnTow's Avatar
MtnTow
Torque convertor also looks different. Having a hard time getting it seated as well but that might just be me.
The new transmission TC has a square weight on it. The new transmission has 92/93 date marks.
The old transmission has no extra square and is marked with 94 date.
