Help Decipher New No Start Symptom Please
Old Apr 12, 2018 | 11:57 PM
KevinSandidge's Avatar
KevinSandidge
I'm still flashing a code 24 with the new tps installed and now i'm getting a code 22 for coolant sensor. Both of those say 'out of range'; what does that mean?
22**
ECT sensor voltage
too high or too low
Engine Coolant temperature sensor input out of normal range. Check engine temperature sensor.
24**
Throttle position sensor
voltage too high or low
TPS sensor is out of normal range.
Thanks!
Old Apr 13, 2018 | 09:02 AM
RalphP's Avatar
RalphP
it means the voltage the ECU is seeing is out of the acceptable range, either too high or too low.
Time to grab the FSM and the voltmeter and see what you ARE getting.
RwP
Old Apr 13, 2018 | 11:24 AM
KevinSandidge
okay then. so what will i be repairing in order to get the voltage back in range? finding a short or bad ground? something like that? thanks buddy
Old Apr 13, 2018 | 11:57 AM
RalphP's Avatar
RalphP
Well, depends on how the voltage is bad, donnit?
But you'd trace the wiring back to the ECU, and see if there's 5V off the ECU or not, and if it's getting to the sensors. Also checking the grounds.
RwP
Old Apr 13, 2018 | 01:37 PM
KevinSandidge
right; got it. thanks again
Old Apr 15, 2018 | 05:31 PM
volaredon's Avatar
volaredon
disconnect battery for a little while and see if they come back
Old Apr 16, 2018 | 12:28 PM
KevinSandidge
even i can do that much; i'll give it a shot. thanks!
