Need some help from the professionals.
Old Jan 22, 2019 | 04:26 PM
  #61
viziers's Avatar
viziers
Originally Posted by Azboyinmi
Yeah Bosch sensors aren't the best for our trucks. They seem to like densos though.
id still swap those injector connections though. Just switch 6 and 8 connections and see what happens. Just don't drive it like that unless it seems to fix the problem
Will do, Can't hurt to try thats for sure.
vizi
Old Jan 22, 2019 | 04:29 PM
  #62
RalphP's Avatar
RalphP
Originally Posted by viziers
So you are suggesting crank sensor from dealer and denso O2 sensor from parts store?
vizi
Or both from the dealership.
RwP
Old Jan 22, 2019 | 04:49 PM
  #63
Azboyinmi's Avatar
Azboyinmi
My suggestion wasn't to switch the injectors themselves. Switch the pigtails that come out of the harness and hook up to the injector. Put the pigtails from 6 on 8 and vice versa. Literally just unplug both connectors and pkug them into the other Injector
Old Jan 22, 2019 | 05:28 PM
  #64
viziers's Avatar
viziers
I think I had it right that comment was to add that I also tried to swap injectors themselves but on later post said i cant hurt to try. lol To many posts all at once..
vizi
Old Jan 22, 2019 | 07:16 PM
  #65
Azboyinmi's Avatar
Azboyinmi
Lol try it, lemme know what happens
Old Jan 22, 2019 | 07:27 PM
  #66
volaredon's Avatar
volaredon
Originally Posted by RalphP
One last thing. Have you read the TSB about the plug wiring on these motors?
You may have crossed wires causing a misfire on only one cylinder.
RwP
impossible. you can't cross ONE wire. has to be at least 2 meaning you will have at least 2 misfires.
Old Jan 22, 2019 | 07:32 PM
  #67
volaredon's Avatar
volaredon
when I got my 93 (no longer have, wrecked badly) it came to me with #5 and 7 injector pigtails crossed from the PO.
Old Jan 22, 2019 | 09:10 PM
  #68
RalphP's Avatar
RalphP
Depends on where they are in the firing order, donnit?
I mean, yah, both cylinders fire; but only one misfires because the OTHER one is on exhaust or some such.
RwP
Old Jan 22, 2019 | 09:30 PM
  #69
Azboyinmi's Avatar
Azboyinmi
Ralph in that case you might have a misfire on o e cylinder while the other cylinder might be considered dead.. I think.... Depends on where the switched cylinders are in the cycle
Old Jan 22, 2019 | 09:32 PM
  #70
RalphP's Avatar
RalphP
Not switched; just an extra fire at the wrong time due to induced current.
RwP
