Battery gauge is maxed out almost
Old Apr 7, 2018 | 10:44 PM
Josephrking's Avatar
Josephrking
Default Battery gauge is maxed out almost
Hey guys,
so on my 93 the battery voltage gauge is dang near maxed out. I can’t remember exactly where it’s at.
but there’s no problems whatsoever that I can tell from this so my question is what is it? Regulator of some sort?
Should i I fix it?
thanks
Joe
Old Apr 7, 2018 | 11:23 PM
RalphP's Avatar
RalphP
First off, take a voltmeter (a digital; even a Harbor Freight one!) and see what voltage you're getting when the gauge is maxed out.
The regulator is in the ECU, so hopefully it's more a bad meter than the system running too high; but if it is, you can use an external regulator on your alternator and get the voltage right.
RwP
Old Apr 8, 2018 | 08:59 AM
Josephrking
RwP
awesome will do! Thank you
Old Apr 8, 2018 | 03:47 PM
onemore94dak's Avatar
onemore94dak
I have a statement and a question.
I had an overcharge indicated on my dash. I was directed I forget by whom to getting my battery checked. I replaced it and the charging went back to half or less.
If I were to have this issue again where would I test with my Harbor Freight voltmeter?
Old Apr 8, 2018 | 04:38 PM
RalphP's Avatar
RalphP
First is at the battery; second is at almost any 12V tap (I have a voltmeter that plugs into the cig lighter and gives me two USB ports also, plus a pair of pass-through aux sockets not rated for a cig lighter but great for a secondary device like my radar detector).
RwP
Old Apr 8, 2018 | 05:35 PM
volaredon's Avatar
volaredon
yeah when batteries die these trucks can do all sorts of crazy things..... when the one in my Wrangler died the charge gauge pegged...... soon as I replaced the battery it went back to normal/
also between my 92 and my 96 Dakotas that are functioning fine the needle stays closer to 1/2 gauge on the 96 and normal running on the 92 is about 3/4 scale and has been in the whole 40k miles I have owned it.
Old Apr 9, 2018 | 12:34 PM
ragged89's Avatar
ragged89
RwP
Ralph, I have one of those cig lighter voltage gauges too, very useful, it has the USB outlet as well. A couple of times the readout has started to flash on mine, I haven't caught the exact voltage at which it begins to flash, but its around 14.8V. Think it might be trying to indicate an over-voltage condition, but at less than 15V it seems a little overly sensitive to me. Anyway, if I turn the headlights on it drops the voltage and the display stops flashing.
Anyway, it has come in very handy as a troubleshooting device. My wife's Kia was having a starting issue a while back, wherein it would start right after being driven but wouldn't if I came back a couple hours later. I'd have to charge the battery to get it to start again. I thought maybe I had a draining issue, until I plugged the cig lighter gauge in. I noticed the battery voltage began dropping right away; slow enough that it would start if tried again soon, but in as little as 6-7 minutes it would show weakness. Even headlights shouldn't drag a 2 year old battery down that fast, so I had the battery checked - it was faulty. That gauge also lets me know when its time to put a trickle charge on my garage queen Dakota. She don't get driven much in the winter.
