87 Dakota 2.2l fuel pump
Old May 8, 2018 | 10:08 AM
ughmas's Avatar
ughmas
Default 87 Dakota 2.2l fuel pump
Hey all, new to the forum and new to owning a Dakota, bought an 87 Dakota 2.2 5sp project that has been sitting still in a parking lot for 10 years, trying to get it running as a barn beater.
Long story short - tackling the fuel system first, it had some old gas varnish built up in it - trying to locate and replace the fuel pump and I am getting some conflicting information - the gas inlet and outlet lines were already disconnected in the engine bay when I bought it (I have the bed off and access to the whole lines)
I have the Haynes manual and from other resources they all show that the 87-88 2.2l has a mechanical fuel pump bolted into the engine block. I know exactly what it should look like from shopping replacements, but I have looked at everything inside the engine bay and I cannot for the life of me, find where its located. Does anyone have some insight on this?
Thanks in advance, I can provide pictures if needed.
Old May 8, 2018 | 11:31 AM
RalphP's Avatar
RalphP
You won't find it in the engine bay, but on the engine.
The parts list show the same engine and fuel pump for 1987 and 1988; here's the page from my 1988 FSM on where the pump is, and how the fuel lines run, attached as a PDF.
RwP
File Type: pdf
Old May 9, 2018 | 08:23 AM
ughmas's Avatar
ughmas
RwP
Thanks so much for the diagram and info, that is exactly where I expected it to be based on looking around the web... however when I look on that part of the engine I simply dont see it, or where it would bolt in... I see the AC compressor oil filter distributor and everything else but nothing that looks like the fuel pump... I will try to take a picture when I get home.
Thanks.
Old May 10, 2018 | 08:53 AM
ughmas's Avatar
ughmas
Thanks.
Here's a picture of the engine as it sits right now and a video of the location where its supposed to be... still scratching my head on this one
Old May 10, 2018 | 06:27 PM
RalphP's Avatar
RalphP
I dunno, dude. You may need to pull the alternator and A/C comrpessor (pro tip: Unbolt from the motor and lay it over where the battery normally is) and look there.
Can we get a picture of THAT side, after you pull them?
RwP
