93 3.9L Bad PCM?
Old Jun 4, 2018 | 01:18 PM
Wireless-T's Avatar
Wireless-T
Default 93 3.9L Bad PCM?
My 93 3.9L turns over, but does not start. Here are my observations:
- No power at coil during cranking
- No power to injectors
- ASD is open, but have confirmed relay is good
- No signal from pickup coil due to no 8V supply coming from PCM pin 7
- Also NO 5V supply on pin 6 of PCM
- PCM pin 3 DOES have 12V battery voltage
Appears that the PCM is defective. Before I drop $150+ on a new unit.....am I overlooking anything?? Thanks to all the other related posts that helped with the troubleshhoting. You guys are awesome!
Old Jun 4, 2018 | 10:48 PM
Azboyinmi's Avatar
Azboyinmi
Ok ur gonna have to chase down the fusible links in the wire harness. Theres a good number of them. The main ones you're worried about are in the first 11/2 to 2ft of wire harness coming out of the fuse box under the hood. I actually had a couple of those links blow and short causing my pcm to get fried. I rebuilt my entire harness and rebuild every solder link then heat shrunk them it was alot of damn work, but I did it right so I won't t be worrying about it in the future. Click on my name and look at the threads I've posted, there was 1 or 2 on the wire harness
Old Jun 6, 2018 | 09:14 AM
tbugden's Avatar
tbugden
I'm pretty sure I'll have no use for my '93 V6 PCM going forward, and I sure don't want a hundred fifty freakin dollars for it (seriously?). As long as you promise to use it and not flip it, I'll sell it super cheap. PM me when you've narrowed it down to the PCM for sure after taking the advice from Azboyinmi.
