Where is the driver side footwell lamp located?
Old Jul 27, 2018 | 12:52 AM
93422's Avatar
93422
Default Where is the driver side footwell lamp located?
The footwell lamp for the passenger side works but the driver's side does not, either the bulb is burned out or it's missing.
I looked under there and wasn't able to find either the bulb or the housing. Google was no help at all, nor was the owner's manual. Currently looking at the FSM, but under the section that deals with lamps, there's no mention of it and at this rate it doesn't look like there's going to be any mention of it anywhere in the FSM. Help please!
Old Jul 27, 2018 | 07:50 AM
RalphP's Avatar
RalphP
There isn't one.
(The fact that there's not one shown in the wiring diagram might be a hint!)
If you want one, wire an extension cable to the passenger side wire, and add one. I'd use a LED strip if I add one there.
RwP
