bolt locations /angle differences in LA 318 vs Magnum 318
Old Oct 23, 2018 | 05:33 PM
RalphP's Avatar
RalphP
Isn't the original motor TBI? Will the throttle body bolt to an aftermarket intake?
It is.
There are 2BBL/4BBL adapters.
Of course, ideally, he'll return that Magnum and get a LA motor.
Secondly, use that intake, upgrade to a good 4BBL carb, upgrade to a stand alone ignition system, and run the carbed crap out of it.
Thirdly, use that intake, use one of the stealth EFI systems, and run a good modern-engineered TBI/EFI system. May still need the stand alone ignition system.
But ideally, return the Magnum and buy a LA.
RwP
Old Oct 23, 2018 | 09:01 PM
chasebh89's Avatar
chasebh89
Don't need to test for emissions if the vehicle is from 95 or older (take that California) so unless you just want to be nice to the earth I wouldn't worry about emissions testing
