Wheel spacers and hub centric rings
Old Dec 19, 2018 | 11:33 AM
Drys's Avatar
Drys
Post Wheel spacers and hub centric rings
I recently acquired some 2nd gen wheels and rather than shaving down the brake nut, I measured and it looks like I need 1/4" clearance. I found 1/4" wheel spacers (slip ons) but none with the correct center bore size. My '95 has a center bore of 71.5mm and these spacers are 82.5mm. Will that be an issue if the wheels themselves are lug-centric? Or do I need to find a hubcentric ring with an OD of 82.5 and ID of 71.5?
Old Dec 19, 2018 | 05:03 PM
00t444e's Avatar
00t444e
Hub centric rings are unnecessary on a lug centric wheel.
Old Dec 21, 2018 | 10:47 AM
Drys's Avatar
Drys
Can you confirm these wheels are lug centric?
Old Dec 21, 2018 | 12:21 PM
glenlloyd's Avatar
glenlloyd
I don't believe that Dodge wheels are hub centric, then again I can't find any definitive yes / no on the interwebs. You could try any search engine to find out?
At any rate I don't think they are, but you might have to go to Dodge to find out for sure, but if it concerns you then buy spacers that have a center ring included, it will make mounting the wheels a whole lot easier anyhow.
As it is you will need spacers to run these on gen1 trucks, especially if you bought the 8" wide version, which I wouldn't. The 7" version is perfectly fine, especially on gen 1 where they're going to rub.
Steve
Old Dec 21, 2018 | 12:33 PM
00t444e's Avatar
00t444e
If the lug nuts have a conical seat then they are lug centric, if they are flat then the wheel is hub centric. I know my factory wheels are lug centric.
Old Dec 21, 2018 | 02:15 PM
Drys's Avatar
Drys
My lugs are conical, thanks!
Steve
I honestly don't know the width of the wheel. They have 235 sized tires on them. The rears fit fine, it's the fronts that the wheels rubs on the brake nut.
