'95 2WD - Electrical Problems
Old Apr 23, 2019 | 09:56 PM
RoanokeDakota's Avatar
RoanokeDakota
Default '95 2WD - Electrical Problems
Radio doesn't work.Got two used ones,& neither works,
so I'm thinking it's not the radio.
The interior light doesn't work either.Also,the gas gauge
is jumpy,& won't read properly.
Any help is appreciated.
Old Apr 23, 2019 | 10:58 PM
RalphP's Avatar
RalphP
Step 0 - Download the factory service manual from the link in the FAQ.
But - I'd be checking grounds, fuses, and connectors.
RwP
Old Apr 23, 2019 | 11:29 PM
RoanokeDakota
Forgot to add that I checked the fuses.
Old Apr 24, 2019 | 06:52 AM
RalphP's Avatar
RalphP
One thing a lot of people miss on the radios - did you connect the ground wire?
There's no negative return on the wiring harness; our radios use a ground wire to a dash brace.
Next check the connection AT the cross brace; if it's been loose at all, it can corrode enough to cause a no-connection problem.
(Hence the "Check Grounds").
Be sure to pull the factory service manual PDF down from the FAQ; you can use that to back trace the wiring to find out where it's not working.
RwP
Old Apr 24, 2019 | 06:42 PM
96360's Avatar
96360
Theres a really small fuse in the fuse box under the hood. That's the problem. Its like 2.5 or 5 amp.
