2nd Gen 3.9l used as short block for 1st gen
Old May 30, 2019 | 06:50 AM
rene lopez's Avatar
rene lopez
Default 2nd Gen 3.9l used as short block for 1st gen
87 dakota 3.9 sized up. Got 2000 3.9 magnum. Can I use 2nd Gen as short block? Swap carb, intake.....?
Old May 30, 2019 | 08:05 AM
RalphP's Avatar
RalphP
LA intake won't bolt to the Magnum heads without redrilling. Youi'll have no EGR nor heat-bed to keep the air/fuel mixture warm for better vaporization.
The LA heads will bolt to the Magnum block, but the rockers won't last due to the lack of the oiling passages.
IOW, not as easily as rebuilding your current carb'ed LA block.
Now, if you find a 91+ donor truck (91-96; 96 has a slight uptick due to being OBDII), and use a manual ECU (since the 87 is either manual, or 3 speed auto), you might be able to upgrade to a full Magnum truck. You want the donor because you'll just about need all the wiring ...
RwP
Old May 31, 2019 | 12:27 AM
rene lopez's Avatar
rene lopez
Default Oops
tyvm. Seemed like a good idea.
