How to replace back window panel
Extended cab?
Here's the page from the 1996 Factory Service Manual.
*broken record*
If you've got a 1995 or 1996, they're available for download here; for that matter, a lot of the mechanical will be the same back to about 1992 or so. But you SHOULD buy a copy of the factory service manual for your truck if you're going to keep working on it.
The PDF is under $40 at autobooksbishko.com .
*end broken record*
RwP
*broken record*
*end broken record*
RwP
