3.9 to 5.2 swap
Old Oct 2, 2019 | 03:07 PM
Frank Reilly's Avatar
Frank Reilly
Default 3.9 to 5.2 swap
Hi, I have a 1994 3.9L 4WD with a bad trans. I have access to a 1997 Dakota 5.2L 4WD with a rotted frame and I was thinking of swapping the power train.
has anyone done a switch between the years like that? If so what kind of hurdles did you run into?
Old Oct 2, 2019 | 03:50 PM
RalphP's Avatar
RalphP
1994 used EGR, but by 1997 the improved ECU avoided the need for it.
You could hunt up a 1996 V8 Dakota and swap the ECU and wiring harnesses over to take care of that.
The 1994 transmission is a RH transmission; the 1997 is a RE; again, you'll need to choose between a) using the V6 transmission and a 94/95 ECU and adding the extra two injectors; b) using a 1996 ECU and wiring (they went to the RE in 1996); and c) might have to fiddle with the transfer case too.
RwP
Old Oct 3, 2019 | 06:33 AM
Frank Reilly
I can't just use the PCM\ECU and harness from the 97? I don't want to use the smaller trans with the 8 cylinder it already is burnt up.
Old Oct 3, 2019 | 09:21 AM
RalphP's Avatar
RalphP
Well, the instrument cluster on a 1997 is driven off the ECU whereas the 1994 is stand alone. So there's that to confuse matters worse.
Steering column may swap or may not; the front end had several parts redesigned for 1997.
This is going to be a longer drawn out procedure than you think it is, and it's going to cost more than you plan. Just be aware of that.
RwP
Old Oct 3, 2019 | 09:29 AM
Frank Reilly
ok thanks
