How to install Engine Belt 95 Dakota
Old Dec 16, 2005 | 07:24 PM
jry1847's Avatar
jry1847
Default How to install Engine Belt 95 Dakota
Dumb question but how do I install the engine belt on a v6 dakota 95. Diagram is there and easy to do but I couldnt figure where to pry the pullies to slip the belt on.
Old Dec 16, 2005 | 09:40 PM
projectdakota22's Avatar
projectdakota22
Default RE: How to install Engine Belt 95 Dakota
If its anything like mine (which it should be), the pulley on the far left (when facing ur engine in front of the truck) has a spring mechanism which supplies tension to the belt. There is a "bolt head" (15mm I think) where a socket can attach right in front of the middle of the pulley. With the help of a power bar (depending if the spring is seized or stiff) it should pivot over providing you the slack you need for replacing the belt. Hope this helps!
Old Dec 21, 2005 | 01:41 PM
JDakota92's Avatar
JDakota92
Ditto. It's a 15mm head on the tensioner. With the socket/wrench on the tensioner, pull it towards the driver's side of the engine bay. That will give you the slack you need to install the belt.
