T4 10w30 in my 318?
So I've got an oil change due and I'm thinking of running Shell Rotella T4 because I can get it for a bit cheaper but it specifies for Diesel engines so I'm hesitant. Does anyone know anything about those oils or if it's safe to run in a gas 318? I normally run Valvoline full synthetic 10w30, any consequences for switching over?
From what I've read it's rumored that shell lost their gas engine rating only because it has higher zinc levels and it's not goot for catalytic converters, however I thought I'd ask but to make sure.
Do you know how T4 will do versus the Valv 10w30 in terms of thickening up in the cold? I've seen T4 vs T6 oils and the difference is quite a lot
What 00t444e said.
I used to run that until I decided to get my 1988's 3.9 rebuilt; I now run the gas variant.
EDIT: As to thickening up, 10W30 should be 10W30 close enough; what weight is the T4?
RwP
RwP
Diesel oil doesn't get along with cats. I'm running it in my 91 D150 with a 98 360 mag. Build. Run it in my motorcycles also. No friction modifiers, so it doesn't hurt the wet clutch, and the extra zinc, and the cleaning agents help keep everything clean. If you don't have allot of blow by, and your valve seats are good, and a good pcv, or an oil catch can I wouldn't be afraid to run it in a catted gas engine.
The T4 is 15W40 but it's synthetic. The T3 is conventional 15w40.
T5 10w30 sorry lol, it's been a heck of a day
i saw project farms test T5 and T6 15w40 against eachother and the T6 resisted thickening up quite well compared to the T5 (iirc he tests at -40*f)
Trending Topics
I've run diesel oil in gas engines before,no issues.
i got a deal on mobil delvac 15w40 over the summer, bought all they had, as often as I have to change oil. Been running it in my 96 Dakota 318.
Otherwise I run 10w40 year round in everything I own. I have all pushrod engines, a couple of 318s, a 3.9 and a 360 mag. As I have been doing for over 30 years.
