1st gen lift
Has anyone seen or used these lifts for their first gen Dakotas? It is the only front lift I have found , adding 3 inches on top of the 2 1/2-3 inches from torsion keys giving about a 6 inch lift in the front , and lifting the back is as easy as blocking the leafs. What are your guys’ thoughts
This is the first I've seen of these, very interesting. It looks to me that they're for 2wd models though. 4wd didn't use coil springs bc the axle would interfere. I'm also not seeing a spot for the torsion bar to mount.
I might still order a set of these though, I'm making a 2wd tough truck and these might be perfect for that.
