Oil pressure sender/switch before or after filter?
Old Apr 30, 2020 | 03:28 AM
cc.5's Avatar
cc.5
Default Oil pressure sender/switch before or after filter?
Hi, maybe this is an odd question, but does anyone know where the oil pressure sensor channel connects to on a 5.2L Magnum? Does it take the pressure before the filter, or after? If the filter is good, the pressure should probably be the same either way, but I'm just curious. Thanks.
Old Apr 30, 2020 | 09:25 AM
onemore94dak's Avatar
onemore94dak
If it is on top of the motor like the 3.9 Magnum then according to the 95 FSM it is upstream of the oil filter. That is the oil pumps from the sump through the filter first, then the rest of the motor. Its chapter9
Old Apr 30, 2020 | 07:09 PM
cc.5's Avatar
cc.5
Yeah, it's like the 3.9L. Thanks!
