Hard time finding 1995 dakota 3.9l lower steering rod.
Old Jul 7, 2020 | 03:52 AM
william burgess's Avatar
william burgess
Default Hard time finding 1995 dakota 3.9l lower steering rod.
I have looked on every site I know. It hasn't came up. Its the full rod that links from your power steering racks pinion gear then has a damper rod linked to a universal pivot joint then from there links up to your steering column. I had one tracked down with the part number but lost it. Can provide pictures.
Old Jul 7, 2020 | 08:07 AM
RalphP's Avatar
RalphP
Is your column tilt or non-tilt?
I ask because I had to make one for my 1988 tilt column truck.
(The upper end is different between the tilt and non-tilt columns is why I ask.)
If tilt, you can look at this: https://dodgeforum.com/forum/1st-gen...ate-shaft.html
RwP
