1988 Dodge Dakota - Lightbulb Hanging Inside Dash?
Old Aug 28, 2020 | 11:52 PM
Alexander Buck's Avatar
Alexander Buck
Default 1988 Dodge Dakota - Lightbulb Hanging Inside Dash?
Hi,
During the installation of an aftermarket radio inside of my 1988 Dodge Dakota, I came across a seemingly random lightbulb hanging inside the dashboard.
To my understanding, this bulb is wired to the headlight/dimmer switch. With the bulb disconnected, the gauge lights do not come on, and when the headlights are turned on, the radio briefly shuts off. With the bulb connected as shown in the picture, everything functions properly.
Other than being required for proper functioning of the radio and gauge lights, does anyone have any idea where this lightbulb belongs or what it is intended to illuminate? My best guess is that it was used to light up the factory radio controls.
I also found a picture of what seems to be similar, if not the same A/C controls in my truck. My A/C controls are somewhat dim compared to the picture, and in that case, could that be where the lightbulb is supposed to go?
Thanks in advance.
Lightbulb Inside Dashboard
A/C Controls
Old Aug 29, 2020 | 02:08 AM
RalphP's Avatar
RalphP
Originally Posted by Alexander Buck
Hi,
Thanks in advance.
A/C Controls
That bulb probably goes to the cigar lighter / aux socket to light it up. It may also go to the ash receiver, but I'd bet lighter.
The AC control is a burned out 74 bulb. There's three across there. I replaced mine with some 74 warm white bulbs from SuperBrightLEDs.
RwP
Old Aug 29, 2020 | 09:30 AM
onemore94dak's Avatar
onemore94dak
Is that hanging loop a disconnected ground?
Old Aug 29, 2020 | 11:07 AM
Alexander Buck
RwP
I took the dash apart, and sure enough, there was a small cutout for the bulb over the ash receiver.
Thanks for the information on the A/C controls. Two of them are burned out. I'll have to get replacement bulbs.
It is, I had it disconnected temporarily.
Also, do you guys know what type of bulb the 'Maintenance Required' bulb is in the gauge cluster?
Ashtray Bulb
A/C Control Bulbs
Old Aug 29, 2020 | 09:40 PM
RalphP's Avatar
RalphP
194 type. You can leave it out, it's a reminder to service the EGR and other emmision components.
RwP
