Ignition switch replacement
Old Oct 7, 2020 | 08:53 PM
Devon Farber's Avatar
Devon Farber
Default Ignition switch replacement
Ignition switch replacement. So there's no tention between run, and start. Ignition lock and switch are out and off the column and I'd like to know out of that harness what do I need to hook up a push button start bypass.
harness is 7 bay flat, mounts under switch. L to R, is red, blk ,blk/pnk, pnk/blk, 2 wh/blk, blue, yel.
Which do I need to hook up to bypass a push button ignition switch?
Old Oct 8, 2020 | 01:32 AM
RalphP's Avatar
RalphP
Which year?
Despite what you think, the wiring CHANGES some from 1987 to 1996 ...
And, do you have the factory service manual yet?
EDIT: Any particular reason why you'd want to make it easier to steal, instead of just fixing it right?
RwP
