1993 3.9L v6 Dakota ignition wiring help
Old Apr 11, 2021 | 06:16 PM
Scottty's Avatar
Scottty
I have had a no crank, no start. Seems to be no power when I turn the key, but the key ring light turns on so the switch should be getting power.
I found this in the cab, it goes to the four exposed wires that are in the engine bay. Is This is my cruise connector??
Also..... Is the wiring correct on this plug for the ignition switch?
Also, is the wiring correct with this plug, which goes to the steering wheel lock??
Thanks, any help is appreciated
