Need help
Old Jun 15, 2021 | 06:43 PM
Crimsontide0000's Avatar
Crimsontide0000
Default Need help
I have a 1993 Dodge Dakota 2wd lwb, the universal joint went out and in the process it destroyed the yoke. Which drive shafts will interchange with it? Which year models?
Old Jun 16, 2021 | 09:41 AM
onemore94dak's Avatar
onemore94dak
I searched 1993 Dodge Dakota 2wd driveshaft and CARID has a new Dorman one and used ones also came up. If you have the center bearing change it too if you get another shaft.
I have to ask, how did you destroy the yoke?
Old Jun 16, 2021 | 09:54 AM
RalphP's Avatar
RalphP
The driveshaft whanging around did it.
Probably did a number on the output bushing of the transmission.
As to others that will fit - no others from the boneyard, but a 2WD Dakota with the same engine and transmission (and transfer case for 4WD); but by that I mean "V6/V8 and Auto/NV3500/AX15".
There's also 1 piece and 2 piece driveshafts for the LWB; need to match THAT.
For Crimsontide0000 - did you check car-part.com for a driveshaft?
RwP
Old Jun 16, 2021 | 11:19 AM
Glen440's Avatar
Glen440
Would need to know what transmission is in it. 42rh and 46rh are different. Can have it repaired at a driveshaft shop.
Old Jun 16, 2021 | 01:37 PM
RalphP's Avatar
RalphP
Or even IF a 42RH/46RH ... Crimsontide0000 didn't even mention if manual or automatic.
So there's 42RH, 46RH, AX15, NV3500 as a minimum.
RwP
