transmission?
Old Dec 28, 2005 | 02:10 AM
coldducjr's Avatar
coldducjr
Default transmission?
hey guys
I need to know what tranny my duck has
I have a 1994 dakota 5.2l v8. club cab 2wd short bed.
I wanna install a transgo shift kit. anybody ever put one on their trucks? how hard is it, and did it improve the performance at all.
thanks!
graeme
Old Dec 28, 2005 | 08:38 PM
360DakotaPwr's Avatar
360DakotaPwr
Default RE: transmission?
Should be an A518 (at least from a tranny rebuilder standpoint)
Depending on what company or who you ask it is categorized by other #'s ( 46 RE, 42RH, Yata Yata Yata, Whatever, theres lots of #'s that mean the same thing)
Crawl under your truck and look at the tranny pan. If it is rectangular then it is an A500, IF it is rectangular but has a buldge on the right hand side under the dipstick tube, then it is an A518. Should be a 518 for the V8, but there are a coulple of 500 running around out there behind V8's.
Old Dec 29, 2005 | 12:50 PM
Sneezer's Avatar
Sneezer
I have a Transgo that is waiting to go into mine. If you do attempt to do this yourself, take your time and make sure you have a very clean work area. You do not want to muck up a valvebody. I am looking forward to mine when I get the chance to do it. My tranny pan gasket has failed once again, so I may try and do it whan I put a Mopar gasket in instead of the cheap cork ones I've been using, but I also want to put a deep tranny pan in as well, either the Mopar one or LPW.
Old Dec 30, 2005 | 02:50 AM
360DakotaPwr
The cork ones WILL leak within a year. There are new ones out made of some light brown material. They are hard and dont bend easily, but they do not collapse allowing fluid leaks.
Old Dec 30, 2005 | 12:25 PM
Sneezer's Avatar
Sneezer
Yeah, Mopar has a reusable gasket now that pretty much eliminates the problem. I'll pick up one of those when I am ready. Truck is just sitting for now anyway.
