Two things
Old Jul 3, 2021 | 01:58 PM
onemore94dak's Avatar
onemore94dak
Default Two things
1. I may have over tightened the bolt on the computer connector as I cannot get it to back out. I expect the nut portion of the join is no longer being held still by the plastic. Any ideas/experience on solving this?
2. How do you tell what computer you need when there is no marking on yours? I had it off the fender and looked it over the tag is just white like the printing on it wore off.
Old Jul 3, 2021 | 03:45 PM
RalphP's Avatar
RalphP
1) May have to remove the housing and grab the back with a pair of vise grip style pliers.
2) I'd look in the parts listing from here, and check the part numbers there.
RwP
Old Jul 3, 2021 | 03:51 PM
onemore94dak
I assume that means removing the Torx screws?
Edit- Anyone else having website issues? All day it has been hard to get access, like the server was down. Just now I couldn't reply with a quote. My bookmark doesn't work and the site is wonky even while logged in. ?
Old Jul 3, 2021 | 04:36 PM
RalphP's Avatar
RalphP
Yep, removing the torx screws. Not sure what size they are, or if you can even pull the back off with the bolt through. But it's what I would try next.
And yes.
RwP
Old Jul 3, 2021 | 04:54 PM
onemore94dak
OK that did not work for me. I have never taken one apart so I do not know how well the unit is attached inside the backing. I saw no screws threw it. Blew it out with canned air. but I didn't go further. It is probably pressure fit to the housing. It is my only reliable rig so I can't take the chance of it being down.
I got the dealer parts guy on the line and he gave me the "latest" number and the OE one which told me which of the two numbers I got off the parts manual was right and that showed me how to read it If i decide to pull that trigger I will probably have to eat the core fee as I expect I will have to destroy this one to get it off.
