Trans/Extension housing part
Old Aug 4, 2021 | 07:30 AM
Flounderguy's Avatar
Flounderguy
Default Trans/Extension housing part
I am working on my 95, 5.2, automatic, 2wd. I separated the extension housing from the transmission before I dropped the transmission. When I got it off, I looked at the transmission shaft that goes into the housing. Halfway down the shaft, this part was hanging. I took it off but didn’t pay attention to its orientation.
One side has a recessed groove around the outer circumference. The other side has a raised ridge around the inner circumference. Anyone know what this is, and more importantly, which way the side with the recessed groove should face, the transmission or the extension housing?
Old Aug 4, 2021 | 08:27 AM
onemore94dak's Avatar
onemore94dak
It looks like a seal. Do the parts of it move/rotate? Then it might be a bearing.
Old Aug 4, 2021 | 08:44 AM
Flounderguy
It’s not a seal. It’s either a bearing or a spacer.
Old Aug 4, 2021 | 10:15 AM
Flounderguy
That inner raised ridge does turn. So it must be a bearing.
Old Aug 4, 2021 | 10:26 AM
Flounderguy
I figured it out. It only fits flush against the extension housing if the inner, raised ridge faces the transmission.
