Frame Lift
Old Jan 4, 2006 | 02:01 AM
92dodge's Avatar
92dodge
Default Frame Lift
Does anyone know how to lift the frame on a 2wd 92 dakota?
I would like a 2-3 inch frame lift.
Thanks for all your replies
Old Jan 4, 2006 | 11:54 PM
360DakotaPwr's Avatar
360DakotaPwr
Default RE: Frame Lift
Well, you can cut off and weld new spring perches in the rear to put the axle under the leaf springs and even then use lift blocks for more if you want. Or find some replacement springs with a higher lift.
Run a drop spindle in the front, or get taller springs, longer shocks, and adjuster things (cant remember what they are called) to adjust the tires back out.
