1994 dakota
Old Jun 10, 2023 | 09:39 PM
Swampie02's Avatar
Swampie02
Default 1994 dakota
About to do a radiator change on my '94 do the trans cooler lines have o rings? The stuff I bought didn't come with em.
Old Jun 10, 2023 | 10:09 PM
bronze's Avatar
bronze
Not sure. Where did you get your cooler lines?
Old Jun 10, 2023 | 10:42 PM
Swampie02's Avatar
Swampie02
Stock lines but new radiator and I guess I lost the o rings, do I have to buy the lines to have to get the o rings or can I just buy the rings?
Old Jun 11, 2023 | 09:27 AM
onemore94dak's Avatar
onemore94dak
No O rings that I noticed. The issue I had was getting a tool to work on disconnecting the ends from the radiator. I had to buy a metallic set of them and modify the one I used with a grinder so that it would fit. Otherwise it operates like an air hose once you get the tool to seat and push in, just pull it off. To put it back just push it on. Have something to catch the drips. Cat litter at least. An old towel is less messy. If you find an all aluminum radiator let us know here.
