1992 Dodge Dakota 5.2 RWD Auto 318 best Camshaft?
Old Jan 31, 2025 | 04:13 PM
Ravarice's Avatar
Ravarice
Default 1992 Dodge Dakota 5.2 RWD Auto 318 best Camshaft?
Hey there what would be the best upgrade for my camshaft. I have mopar performance computer and obd1 so I'm looking for the best drop in camshaft without a tune thanks to all!!
Old Feb 1, 2025 | 03:10 PM
tndakman's Avatar
tndakman
Follow this link & check the time of the first & 3rd posts-then finish reading the complete post. This may change your mind about doing a cam install.
https://dodgeforum.com/forum/2nd-gen...r-install.html. You might want to also check the Forum about installing new gaskets on the 'kegger' intake.
EVERY Magnum engine that Mopar ever built v6,or v8 had a problem with a plenum chamber leak-sucking oil from the engine blowing it right thru the exhaust system. Might wanna search for some posts on that repair as well. Good luck.
Old Feb 11, 2025 | 03:39 PM
ROCKYTOPTN's Avatar
ROCKYTOPTN
I put an intake manifold on mine with a EFI, and a 20-746-9 cam,6.1 lifters with 61775 heads in a 89 Dakota. Looking for a transmission that will hold up
